There’s so much overlap between the DAX time intelligence functions that there’s probably nearly a dozen different ways to do this. The two I prefer are using DATEADD or the offset functions within @Melissa’s awesome Extended Date Table.
I hope you find these helpful. Give a shout if you need any additional assistance.
Hi @jsavage, did the response provided by @BrianJ help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @jsavage, we’ve noticed that no response has been received from you since the 16th of June. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @jsavage, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Thanks.
