Matty
August 20, 2020, 8:47am
1
Hi DNA Team,
I’ve stuck on something tiny but I don’t understand why the formula does not work as I want to.
Debit Credit.xlsx (18.0 KB)
The attached file data contains 3 rows in query editor I would like to add 4th column call Amount
I tried to write if statement if Debit > 0 then Debit else -1 * Credit but I didn’t get the correct result.
I will appreciate your help.
I would like to have Values of Debit and Credit in one Column whereas Credit needs to be negative.
Hi @Matty
I checked your file and saw that you have null in rows as value.Just changed null to 0 for both credit and debit column and you are good to go.
Hope this helps.
Regards,
Hemant
Matty
August 20, 2020, 9:47am
3
Thank you @Hemantsingh ,
I thought when I converted a table to number the empty cell will be treated as 0 but I was wrong
Hey @Matty
If my solution has solved your issue than accept it as solution for others in the community.
Regards,
Hemant
