Hi, I am trying my Save my changes after Transform Data, and I’m getting this error. I am connecting to a Teradata source, and I was not getting this before, does it have to do with my queries, or something else?
How can I fix it?
Thanks!
How can I fix it?
Thanks!
Hi @lplata, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hi @lplata, we’ve noticed that no response has been received from you since the 12th of April. We are waiting for the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
