Hi EDNA team,
I am learning the course “Python II for Power BI Users”. That is a great course. However, the Resources Pack provided is missing datasets for the course (ex. "reddit_wsb.csv’,…) and May I have .pbix file of the final dashboard? Thank you.
Please also note that
The property UNICODE_EMOJI was removed in version 2.0.0 of this module. So it is used EMOJI_DATA instead as a replacement for UNICODE_EMOJI.
In new version function cell :
#create emoji function
def get_emojis(sentence):
sentence = " ".join(sentence)
words = word_tokenize(sentence)
emojis = [e for e in words if e in emoji.EMOJI_DATA]
return emojis
Enjoy this great course.
Hi @mspanic,
Thank you for your instruction.
In terms of the property UNICODE_EMOJI, yes, I replaced EMOJI_DATA in my version. But, both UNICODE_EMOJI and EMOJI_DATA only count emojis that stand alone, they cannot count emojis that appear consecutively as below:
Did the response from @mspanic (thank you!) help solve your query? Please mark the answer as the Solution.
Due to inactivity, a response on this post has been tagged as “Solution”.
Hi Maja,
Because I need to delivery the analytics to users so I did in Power BI. But when I published to Power BI service, some libraries such as ‘nltk’ or ‘emoji’ weren’t supported, so what should I solve this issue? Thank you in advanced for your advice.
