Hi ,
I need to create PBI file using data from attached .txt achieve this view below :
sample - dui .txt (886 Bytes)
It should look like below in Power Query:
DUI - example .csv (1.5 KB)
DUI - example.csv - I created to show how it should look like in PBI
Lines starting with “V” are crossed off and I don’t need them.
Could you please help me to find appropriate and correct steps ( M code)to complete this task. My original is made up of hundreds of paragraphs like 4 ones above in screenshot.
This is something similar to my request , however I am unable to get correct result: Complex data from txt file into power query - help requested
Many thanks in advance - Iwona
