Hi All,
I was just asked to take over a report from a co-worker, but I haven’t done this before. I have only built and deployed my own dashboards and reports. What is the best way to do this? Can he give ownership to me on the Power BI Service and then I can download a copy to work on? Does he have to send me the .pbix file? Thanks in advance for your advice here.
~Julie
Hello @Jewelsdpu,
Thank You posting your query onto the Forum.
Well it would be great if you can receive the Power BI report from the previous developer. Although you can simply download the report from the Power BI Service also. But the main thing is about the data source. If your data source is SQL Server then you’ll also be required the access as well as the queries written to retrieve those data and paste those queries under the Source options in order to activate those tables. Or if the data source is simply Excel or CSV file then just retrieve that file from the previous developer and change the source location or if the data source is OneDrive or SharePoint (Business) then no need to be worried about since all the files are stored at one location.
Hoping this helps you.
Thanks and Warm Regards,
Harsh
Hi @Jewelsdpu, we’ve noticed that no response has been received from you since the 27th of August. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
