Tabular Visual in Power BI without repetition of measures
Hi All,
I am new to Power BI and learning from enterprise DNA. I have completed 2 units in Data Analyst Pathway and still learning more. I am able to create a measure and clean using Power Query.
My manager want a report in tabluar format and I am having problem in delivering that.
Due to sensitive data I have made a dummy data and a visual in Excel which I need to deliver in Power BI which is uploaded as dummy.xls
Here, I will explain a bit about the data.
This is a sales data. Shyam is a sales represenatative for Paramatta Store Pty Ltd and Clyde Store Pty Ltd located in NSW. Both the store has different brand and products. Paramatta Store Pty Ltd has two brand named : Mahi and Dhoni. It has Product A, Product B and Product C realted to Mahi Brand and Product X and Y related to Dhoni Brand. Similarly, the Clyde Store Pty has product related to Dhoni and Jaddu and do not have proudct related to Mahi. The same is for other stores in Excel.
The unique total store (Store count) for each sales rep is not affected by Brand and Product.
The question that I want to answer is
  1. How many unique store count each sales represtative has?
  2. How many of these unique store has atleast 1 product of Mahi Brand (can be either of Product A or Product B or Product C). If the store has atleast 1 product of Mahi Brand, it is counted.
  3. How many of these unique store has Proudct A, Product B and Product C.
  4. Find the percentage of each.
My desire output is pasted here:
The output is in tabular format. Here I will explain the output.
  1. Naisha has 1 unique store (Westmead Store Ltd) which has two products of Mahi (Product A and Product C). Since it has atleast 1 product of Mahi Brand it is counted as 1. So the percentage is 100%.
    Now we want to see if the store has all three products or not. We see that store does not have Product B of Mahi Brand. So, it is 0 for Product B.
  2. For Shyam, he has two unique store (Paramatta and Clyde). Only one of the store has atleast 1 product of Mahi Brand so, the count is 1 and percentage is 50%. Similary, out of 2 store only 1 store has Product A, so percentage is 50% for Product A and so on.
  3. For manager Ram, he as 3 store (2 from Shyam and 1 from Hari). Out of three unique store only 2 store has atleast 1 product of Mahi, so percentage is 66.67%. Similary, out of 3 store for Ram only 1 has Product C of Mahi, so the percentage is 33.3%.
This is what I want to achieve in Power BI. I have a slicer as well, whcih gives the end user to select the Brand name So, if they select other Brand say (Dhoni), they should get similar visual but with product name of Dhoni is the coulmn instead.
I have created measures to find distinct store and percentage but wheneven I put the brand name is the visualzation, I get every repetition of the measure in the column. i.e. the total store and percentage gets repetead in all the product name.
I would like to thank you in advance for all your help and suggestions and helping me hone my skills and knoweldge in Power BI.
@SamMcKay @EnterpriseDNA Request for your guidance.
Link to pbix file
Comment on the Measure
I have made three meausres
  1. Total Store : This counts the total number of store. This measure is unafffected by brand and store name . As total store is the total number of store avaiable to the company.
  2. Store Count : Number of store for each sales rep and each product.
  3. Percentage : Store Count / Total Store
I have create a matrix visualization. You can see that Total Store measure is repeated for every product (A,B,C) and I am not able to create the desired visuals.
Thank you.
Hello, and thank you for your first post to the Forum.
I noticed you didn’t provide a PBIX file. Providing one will help users and experts find a solution to your inquiry faster and better.
  • A clear explanation of the problem you are experiencing
  • A mockup of the results you want to achieve
  • Your current work-in-progress PBIX file
  • Your underlying data file (to allow us to go into Power Query if necessary to transform your data and/or data model – often DAX questions really end up being data modeling solutions)
Thank you!
@ystroman Thank you for the suggestion I will add the pbix in the above query
Bumping this post for more visibility from our experts and users.
