Tables - freeze option to filter
Hi All
I have my tables setup in a specific order. How can I lock it, so that a user does not accidentally click on on of the headings and then sorts the data based on the column header they clicked on?
Kind regards
Stuart
Hi @Stuart,
You can place a transparent shape over your column headers to prevent this.
I would also recommend enabling “maintain layer order” in the general section.
I hope this is helpful.
