Hello @AliB,
Here’s the solution and the measures provided for the reference to achieve the correct totals -
1). Measure For Total Value - Totals -
Total Opp Value - Totals =
SUMX(
SUMMARIZE(
Opportunity ,
Opportunity[OppID] ,
"@Totals" ,
[Total Opp Value] ) ,
[@Totals]
2). Measure For Total Open Opp Value - Totals -
Total Open Opp Value - Totals =
SUMX(
SUMMARIZE(
Opportunity ,
"@Totals" ,
[Total Open Opp Value] ) ,
[@Totals]
3). Opps per Group using Total Opp Value - Totals -
Opps per Group using Total Opp Value - Totals =
SUMX(
SUMMARIZE(
account ,
account[AccountID] ,
"@Totals" ,
[Opps per Group using Total Opp Value] ) ,
[@Totals]
4). Measure for Aged Opp Value - Totals -
Aged Opp Value - Totals =
SUMX(
SUMMARIZE(
account ,
"@Totals" ,
[Aged Opp Value] ) ,
[@Totals]
Lastly, here’s the screenshot of the results that you were trying to achieve.
I’m also attaching the working of the PBIX file for the reference as well.
Important Note: This technique is already showcased in the post which @Greg had provided earlier. You can go through that post again for the reference.
Thanks and Warm Regards,
Harsh
PB Test Model - Harsh.pbix (150.7 KB)
