In a course of development I may change the source for a query multiple times. I have started always putting a remove other columns as my last step in the Query editor to try to minimalise the impact of changes.
How do I know when I have the old query and the new that the column names and data types are the same? I guiess also some sort of sense check of the data may be a follow up question.
So in SQL Server I would use sysobjects and syscolumns to give me a list of columns and how they are defined for a table and then compare the column names and data type definitions.
I have tried %SYSTEM.DBSCHHEMA_COLUMNS but this only appears to give a list of column names
E
