Switch True() - Deciding between 2 calculations
Trying to have a measure calculate a new column. I am using switch true to have it determine between two equations.
Colum A for this example is Cycle Time
Column B is mold cavitation
I am trying to calculate throughput. If Mold Cavitation is blank or 0, I want this equation:
(60/Cycle Time)*60.
If Mold Cavitation is NOT Blank and is above 0, I want it to multiply the original equation by the number of cavities:
(60/Cycle Time)60Mold Cavitation.
I have tried so many variations but it always comes back with ā€œtoo many columns, cannot return a scalar valueā€.
I have attached an example where I directly used filters and equations in the Switch True formula, and an example where I used other measures, with those measures attached. Please help!
Hi @stiefel.ed.
To help us further analyze your current state and visualize your issue, could you please provide as many as you can of:
  • Your work-in-progress PBIX file, using sanitized data if necessary
  • Your dataset as an Excel file (again, sanitized if necessary)
  • A detailed mock-up (marked-up screenshot or Excel file) of your desired outcome.
Also, if you provide DAX in your post, please format it using the built-in formatter.
_eDNA Forum - Format DAX
This error is happening because the DAX expression is expecting a single value but gets a table of values instead.
I’m sure you have done your research, but this article seems like it may help you: (https://www.sqlgene.com/2019/04/30/dax-error-the-expression-refers-to-multiple-columns-multiple-columns-cannot-be-converted-to-a-scalar-value/)
Calculate- Averagex- Then the Switch True () worked! I figured it out. Thank you!
If you wouldn’t mind, please post the calculation that worked for you. It appears that you just changed the order of the calculation and it worked, however, I’m sure I will encounter this error sometime in the future and would love some insight into how you were able to resolve the error.
Thank you.
Here is what worked for me:
AVG Conventional Throughput =
AVERAGEX(ā€˜Case Study Database’,
SWITCH(
TRUE(),
NOT(ISBLANK(ā€˜Case Study Database’[MoldCavitation])) && ā€˜Case Study Database’[MoldCavitation]>0, DIVIDE(60,ā€˜Case Study Database’[ConventionalCycleTime])60’Case Study Database’[MoldCavitation],
ISBLANK(ā€˜Case Study Database’[MoldCavitation]) && ā€˜Case Study Database’[MoldCavitation]<=0, DIVIDE(60,ā€˜Case Study Database’[ConventionalCycleTime])*60,
DIVIDE(60,ā€˜Case Study Database’[ConventionalCycleTime])*60 )))
// This formula calculates the average conventional throughput (in parts per hour). If mold cavitation is entered, it calculates parts per hour as (60/Cycle Time)60Mold Cavitation. If no mold cavitation entered it assumes cavitation of 1: (60/Cycle Time)*60.))))
