Can some one share detailed Tutorial on SWITCH Function please.
Regards,
Rohit
Regards,
Rohit
Thanks for this.
There is one detailed , where he refers to the Webinar not able to locate same pls.
I see that Sam has referred to a workshop however, the Video shared in the description doesn’t seem to be available anymore.
Check out the following videos. Since they all use this function in different scenarios, it should help you with a better understanding.
I hope that helps.
you can visit dax guide. it is well explanatory site for dax functions
Hi @Rohit1, did the response provided by the community members help in solving your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @Rohit1, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
