SWITCH formula (from Sam's video)
Hello - I copied this formula from one of Sam’s videos talking about Weekends and Weekdays.
But I get an error message. In fact, what happens is that when I hit “enter”, the formula changes and adds )))))) with a red line under the last one. And it’s telling me the minimum argument is 3.
Any idea why?
Weekend or Weekday = SWITCH(TRUE(),
DATE(DateTable[DayInWeek] = 1, “Weekday”,
DATE(DateTable[DayInWeek] = 2, “Weekday”,
DATE(DateTable[DayInWeek] = 3, “Weekday”,
DATE(DateTable[DayInWeek] = 4, “Weekday”,
DATE(DateTable[DayInWeek] = 5, “Weekday”,
DATE(DateTable[DayInWeek] = 6, “Weekend”,
DATE(DateTable[DayInWeek] = 0, “Weekend”,
BLANK() )
@richmont,
You don’t need the DATE() function here. This should work as a calculated column:
Weekend Weekday =
SWITCH (
    TRUE (),
    DateTable[DayInWeek] = 1, "Weekday",
    DateTable[DayInWeek] = 2, "Weekday",
    DateTable[DayInWeek] = 3, "Weekday",
    DateTable[DayInWeek] = 4, "Weekday",
    DateTable[DayInWeek] = 5, "Weekday",
    DateTable[DayInWeek] = 6, "Weekend",
    DateTable[DayInWeek] = 0, "Weekend",
    BLANK ()
As a measure , you will need to wrap each DateTable[DayInWeek] in SELECTEDVALUE(). I would recommend doing this as a calculated column in your date table using the code above (or alternatively doing it in Power Query).
Hope this is helpful.
Thanks Brian!! Was trying to do it from memory and that was indeed the problem.
Cheers!
