Hello EDNA - help w/ why this may not be working. current error: The end of the input was reached.
I want to multiply rate by the sum of pieces measure. this rate will very depending on the period selected in the date slicer (disconnected calendar).
based on what I have found I put this together. PBI fill will come if required. just hoping someone can see the error that I might have in my formula:
Pieces Max Pcs Count Spend =
VAR _Selecteddate = SELECTEDVALUE(CalendarFree[Date])
SWITCH(TRUE(),
_Selecteddate >= DATE(2025,3,1), [Pieces Max Pcs Count]*0.028,
_Selecteddate >= DATE(2024,9,1), [Pieces Max Pcs Count]*0.024,
_Selecteddate >= DATE(2024,3,1), [Pieces Max Pcs Count]*0.018,
_Selecteddate >= DATE(2023,7,1), [Pieces Max Pcs Count]*0.012
thank you in advance,
Frankee
