I would like to create a variance measure that can switch between “Budget-Actual” and “Actual-Budget” depending on the Revenue and Expenses categories respectively.
The measure should change according to the category values in the profit & loss matrix. I don’t want to use any Revenue/Expenses slicer (filter button).
I hope you can help me team.
Profit & Loss.pbix (1.6 MB)
Think this Dax works
Variance BU AC CalcCol =
([Total Actual] - [Total Budget])
If it doesn’t you may need to just play/fiddle with the dax by mulitplying by +1 or -1 depending on the line you displaying.
So add
*If(MAX(‘Chart of Account V2’[STDC 0])=“Revenue”,-1,1).
This may help
Pete
Thank you so much for that detailed answer @BINavPete
We hope this helped you @Rodrigo_Palomino
Thanks Pete.
I’m about to post a new challenge related with this solution…
