Is there a way I can switch from Units to Value in Calculation groups.
Currently my matrix is displaying Total Sales measure.
My calculation
My calculation
Do you want to change the number format from integer to currency?
If so, you need to enable dynamic format
No, as you can see from the screen shot I have on top Field Parameters, and I have also used Calculation Groups for Time Intelligence, but these are showing only Total Sales, is there a way that I can use slicer or Field parameters or even calculation groups to switch between Total Sales and Total units sold. Currently they only show total sales.
Hi All,
I actually found out the solution by playing around a little bit with Calculation Groups.
Its simple and you need to create another Calculation Group with 2 items referring to Total Sales measure and Total Qty measure and then bring this into a slicer. ![]()
By the way this is done in the new semantic model and not Tabular Editor.
