Supplier Rebate
Hi , I am looking to get some idea on how to develop supplier rebate , and which supplier fall on 95% bracket which means if we spend bit more when get more rebate .
Please point me in the right direction , is there any DNA video I can watch .
Hello Aree,
Welcome in the Forum :slight_smile:
I think I will most probably use some conditional Dax formulas that you can couple with conditionnal formatting as well to highlight the desired outcome :slight_smile: you should look as these videos where its clearly explained how to tackle this:
There are a lot of material that could help you to build what you want to show.
The data visualization tips is another one that you can look at and get some ideas for your own report.
Cheers,
Julie
Hi @Aree, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Thanks!
Thank you ,
