I have an issue using SUMX and simple multiplication of row by row.
I have the following table .
The column Estimated_number_of animal_fed_by_Purina is
Unless you exactly know what you are doing, I would suggest avoiding including measures into iterator functions as this causes what we call context transition. As a result, your SUMX may not behave as you would expect.
Your 2nd formula is not correct as the first argument of SUM does not do context transition. So, in every row, it will multiply [Total SUM] with your measure instead of sum of that row.
You can watch below video to understand context transition. I believe if you simply wrap first argument of 2nd formula around calculate, it will give same result. Calculate will just do context transition.
Try like : Calculate(SUM(‘Dairy_Selenium’[Ingredient_Tons]))*[Number_of_head_fed_per_year_per_ton]
Hi @gusdcruz, we’ve noticed that no response has been received from you since the 28th of February. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. You may reopen a new thread when the need arises.
