Summarize with filtered measure
Hello,
I am watching the tutorial about using the function summarize and the example is showed below:
I am wondering is that possible to put a filter on the measure of total sales? for example, only total sales larger than 1,000,000 will be summarized in this table. I tried this:
summarize =
VAR NoFilter = SUMMARIZE(‘Regions Table’, ‘Regions Table’[City], “Total Sales”, [Total Sales])
FILTER(NoFilter, [Total Sales] >1,000,000)
but, it showed an error said “invalid bindings specified”. What is the correct way to achieve this? thanks!
@nainu,
Try this:
Virtual Table Filtered =
FILTER(
    SUMMARIZE(
        Regions, Regions[City],
        "Total City Sales", [Total Sales]
    [Total City Sales] > 1000000
I’ve not seen that “invalid bindings” error before , but “1,000,000” (as opposed to 1000000) in your filter condition will cause problems.
@nainiu440,
Definitely never seen that error before, but looks likes @BrianJ solution works.
Also, might want to be careful adding calculated columns in the summarized function. Usually not a problem but when you mix together a filter and the row context in one function it can lead to some interesting results and could be a potential performance hit. I’d use AddColumns and then summarized
ADDCOLUMNS(
   SUMMARIZE(
       ‘Regions Table’,
@Nick_M,
Thanks - nice catch.
thanks all, that works!
