Hi, I am having trouble with the below Dax calc which I am running through Dax Studio to test:
EVALUATE ADDCOLUMNS(
SUMMARIZE(
Group_GLE,
Group_GLE[Entity_Curr],
Group_GLE[Period]
"Entity_Value", CALCULATE(
SUM( Group_GLE[Entity_Value] ),
FILTER(
Group_COA,
Group_COA[AccountNumber] <> 4150 &&
Group_COA[AccountNumber] <> 5150
"Group_EXRate", (
LOOKUPVALUE(
Group_EXRates[ER],
Group_EXRates[Period],
Group_GLE[Period],
Group_EXRates[To_Curr],
"GBP"
) / LOOKUPVALUE(
Group_EXRates[ER],
Group_GLE[Period],
The problem is the filter for the “Entity_Value” section, if i remove the filter the results are correct but when i put the filter in which i need the results do not work.
Any help on the filter and the overall Dax in case there are other efficiencies i should adopt would be very much appreciated.
Below is a copy of the table that Dax Studio produces to give you a better ide aof what i am doing:
