Sum of cumulative measure
We got (thanks to @powerbideveloper a measure which calculates cumulative sales in table like below
pic
The measure is:
    Sales_Cumulative =
    VAR LastSalesHour = CALCULATE ( MAX ( Sales[Dateto] ), ALL ( Sales ) )
        IF (SELECTEDVALUE ( Sales[Dateto] ) > LastSalesHour,
            BLANK (),
            CALCULATE ([SalesDaily],
                FILTER (ALLSELECTED ( Dim15mPeriods ),
                    Dim15mPeriods[Dateto] <= MAX ( Dim15mPeriods[Dateto] )
We have also a second need.
If we have two lines in the same table, but we have more than 1 Store, we need another measure that will be a sum of cumulative sales for this “datefrom-dateto” period for a day, so it will be the same value in both rows
also, sum of cumulative sales_exceptSelected must be the same sum, but except value of Sales_Cumulative in current row.
Date / Weekday / StoreName / Datefrom / Dateto / Sales / Sales_Cumulative / Sum_Sales_Cumulative / Sum_Sales_Cumulative_ExceptSelected
01.04.2019 / Monday / Store1 / 11:15 / 11:30 / 68.10 / 71.90 / 351.90 / 280.00
01.04.2019 / Monday / Store2 / 11:15 / 11:30 / 100.00 / 200.00 / 351.90 / 151.90
01.04.2019 / Monday / Store3 / 11:15 / 11:30 / 50.00 / 80.00 / 351.90 / 271.90
how to create Sum_Sales_Cumulative and Sum_Sales_Cumulative_ExceptSelected measures?
Hi @Harris, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hi @Harris
Please share a sample PBIX file for us to look into this.
Ankit J
Hi @Harris, we’ve noticed that no response has been received from you since the 30th of April. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
I will shorten the discription of what we need. A measure that will be a sum of cumulative sales for selected:
Store
WeekDay
datefrom-dateto
08.04.2019 / Monday / Store1 / 11:15 / 11:30 / 100.00 / 200.00 / 351.90
15.04.2019 / Monday / Store1 / 11:15 / 11:30 / 50.00 / 80.00 / 351.90
how to create Sum_Sales_Cumulative measure?
I also made a solution in attached excel file, on sample data. Sum_Sales_Cumulative is in orange column. Maybe it will help.
Sample PBX and xlsx
Hi @Harris
Can you try this measure
Sum_Sales_Cumulative =
CALCULATE ([Sales_Cumulative], ALLSELECTED ( DimDate ) )
Ankit J
Thank you @ankit
This works as long as we select to see all rows in visual.
But if we’d like to filter f.e. only 01.04.2019, We still want to see proper value in this measure. Can You help us with that?
On the other hand, if we do this:
Sum_Sales_Cumulative = CALCULATE([Sales_Cumulative];ALL(DimDate))
We are close but will get sum for all Weekdays, we want this sum only for selected WeekDay (f.e. Monday)
Hi @Harris
Try this :
    CALCULATE([Sales_Cumulative],ALL(DimDate[DateName]))
Ankit J
