Dplex
1
Hi All, I am trying to write a DAX that will sum a column based on the product name of another column, and am getting the syntax incorrect.
Am trying to calculate:
Variable = Total Product B = Sum (Table 1 [column 1)) , filter Table 1[column 2] “Product B”.
Return
Divide (Total Product B, Sum (Table 1 [Column 1))
Somewhere I’m not writing the syntax or calculation order correctly. Just wondering if someone could assist. Thanks.
Harsh
2
Hello @Dplex,
Try something like this -
Measure =
VAR _Total_Product_B =
CALCULATE( SUM( Table_1[column_1] ) ,
Table_1[column_2] = "Product B" )
DIVIDE(
_Total_Product_B ,
SUM( Table_1[Column_1 ) )
Hoping you find this useful and meets your requirements.
Thanks and Warm Regards,
Harsh
Dplex
3
Harsh, brilliant mate. Thanks very much.
