Hi @vazik.
Here’s some comments:
(1)
To maintain constant role colours when different projects are selected, specify both “domain” and “range” arrays in the “scale” block inside the “color” block.
"color": {
"field": "Role",
"sort": [
"AICT","BI","B.V.","KC1",
"KC2","KC3","KC4","RPA"
"scale": {
"domain": [
"range": [
"#93B7D5","red","#D7CBFD","#1E7B9F",
"#D59ACE","#98D0A9","#002776","green"
(2)
To add totals to each column, add a new “text” mark with a “transform” block containing an “aggregate” calculation for the total, then use the new field.
"name": "PERIOD_TOTAL",
"transform": [
"aggregate": [
"op": "sum",
"field": "Žádanky",
"as": "_total"
"groupby": ["Rok/Měsíc"]
"mark": {
"type": "text",
"color": "black",
"fontSize": 12,
"fontWeight": "bold",
"yOffset": -10
"encoding": {
"text": {
"field": "_total",
"format": ".1f"
"y": {
"field": "_total",
"type": "quantitative"
Hope it helps.
eDNA Forum - Deneb Stacked Column Chart.pbix (1.6 MB)
