i don’t see anything else that i can see. You may not have any other choices without setting up at the beginning but you will then have it completed. Sometimes in projects you have to do the manual work to get the results latter in the project.
Another option is post the question directly on the Microsoft power bi community
This is a sample of Informal Hierarchy to handled the Drill-Down navigation of the bar chart.
This hierarchy is compose at first level with the time period, at second level the product category and SKU for the last level
Hi @Timmay, did the response provided by @Keith and @jbressan help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @Timmay, we’ve noticed that no response has been received from you since the 15th of March. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @Timmay, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
