SQL Data connection
Hello all
I’m trying to connect to my client’s server. He gave me the data that i need, server name, database name, username and password. I have this result, which i think it means, “the problem is on the other side”:
Capture
Can i do something here, “on this side” to ensure that in fact the problem is on the other side?
Thanks a lot
Pedro
Hello @pedroccamara,
Well by judging at the error and the statement it says - “Verify that the instance name is correct and that SQL Server is configured to allow remote connections”. I guess you need to establish a connection via VPN option. Please check with the client whether their data is based on VPN or not.
Hoping you find this useful and helps you to solve the problem. :slightly_smiling_face:
Thanks and Warm Regards,
Harsh
yes, problem solved @Harsh
I should have installed the vpn first.
Thanks a lot
Best regards
I’m glad that I was able to assist you. :+1:
Harsh
