Split multiple columns on rows
Hi @Sam,
I’ve to split rows into columns whose content is a set of values (4 in this case) to be normalized in rows.
I did already get the result I needed using just the UI and some intermediate queries, but I was wandering if this could be done dynamic, that is that may work for different number of values.
Thanks for your help
Roberto
splitting multiple columns.pbix (24.0 KB)
Hi @Roberto,
Is this an accurate representation of your data OR is it intended to represent a Record type value in the last 2 columns?
If that’s how your data is actually structured, you can give this a go. Just copy and paste into a new blank query:
let
    ColsToTransform = { "Probabilities", "Knowledge articles" },
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("jY9BCoAgEEWvEq4l/jhpzrZWEXQB8xjdPyNE0UXthsfM400IajtWw0RsZVJahfMCzIzR+3fSQyawHWlBPorFtC8gOCONLmFY9uI6TPDC/XYtiSrqEu5g63A3tVVkvkm+asppZqG+5cH4/VAlSeXxBg==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Incident = _t, Probabilities = _t, #"Knowledge articles" = _t]),
    Step1 = List.Accumulate( ColsToTransform, Source, (state, current)=> Table.TransformColumns( state, { current, each Splitter.SplitTextByAnyDelimiter({", ", ","})( Text.Remove( _, { "[", "]", "'" }) )} )),
    Step2 = Table.AddColumn(Step1, "NewValue", each Table.FromColumns( { [Probabilities], [Knowledge articles] }, ColsToTransform )),
    Step3 = Table.RemoveColumns(Step2, ColsToTransform ),
    Step4 = Table.ExpandTableColumn(Step3, "NewValue", ColsToTransform, ColsToTransform)
in
    Step4
ColsToTransform = hard coded list with column names to transform
Step1 removing unwanted characters and turn cell content into lists for the ColsToTransform
Step2 turn the lists into a table on a row by row basis
Step3 remove the original columns now present in the neste table
Step4 exapand the nested table columns
I hope this is helpful
Hi @Melissa ,
the representation is accurate and your solution is awesome (as usual).
I’ve tried to use a different number of elements in the columns and worked nicely.
Would you be so kind to better explain step 1? I see many embedded function and function call (looks like python lamba).
Thanks so much
Roberto
I’ve annotated it below, hope that helps.
You might also want to read Rick de Groot’s post, this also includes a link to his blog.
and this post by Gill Raviv
… maybe a video is helpful as well
