I want to split this column by comma, into each occurrence to have it’s respective column, but when i used the each occurrence using comma as my delimiter, I only have two columns splitted when I was expecting like 50 columns.
So the only real column that you really want to split is “Req_Response” correct?
That column is really messy, my first thought is go back to your source and see if you can all the columns that you really need in the file that you don’t have split
Is there any better source that you can get the same information from?
Sorry, I think you are going to have alot issues parsing that. they are not all the same length in size.
