Snowflake schema model
I am building a model using direct query by connecting to oracle database and would like to know if i can build snowflake schema model in power bi data model !
Swapnil
The quick answer is yes it is possible. I would suggest doing a online search for what exactly you have questions with regarding the snowflake schema model in Power BI. I would suggest trying to start to build your model, and if you run into any snags along the way, provide a detailed question here in the forum so that one of us can answer your question.
Cheers
Jarrett
