Please where can I find the slides for the course: DP-500 Prep: Data Transformation with Synapse & Power BI . I have looked everywhere within the course and can’t seem to find it. Can someone please point me in the right direction. Thanks.
Did you go through the resources section?
I hope this helps.
Keith
Yes I did. It isn’t there. All that’s there is files and resources for the course not the main slides the tutor uses in teaching
H @DareEmmanuel ,
LIkely that will be @EnterpriseDNA decision to release the slides of what they delivered within the course. I know from other courses they didn’t release the slides.
Keith
