hello,
in the power bi report I have a slicer which allows me to search for a text…
there are alot of items in the slicer and each one has a checkbox next to it.
There is also a select all check box.
However, I now would like to filter the slicer by entering the text [iron]
This gives me alot of items which have the word iron in it.
so far so good.
Because there are so many of the search returned for iron, how can I have the select all checkbox for all the items of iron so that I do not have to select each one of them?
thank you
Hi @arkiboys,
Based on Data Mentor information:
Power BI currently does not provide a built-in feature to automatically “select all” items in a slicer based on a text search directly within the slicer itself. However, there are workarounds you can use to achieve this.
Steps to Automatically Select All Filtered Items in a Slicer
- Create a Supporting Column: Create a column that identifies rows that contain “iron”.
- Use a Dynamic Filtering Solution: Create measures to dynamically filter based on user input.
- Use these in your Report to facilitate automatic selection
Let’s break this down step-by-step.
Step 1: Create a Supporting Column
Create a new column in your data model that identifies rows containing the word “iron”.
- Go to the
Modelingtab in Power BI Desktop. - Select
New Column, and create a new calculated column using a formula similar to the one below:
ContainsIron = IF(
SEARCH("iron", Table[YourTextColumn], 1, 0) > 0,
1,
0
Copy
Code Explainer
Explanation: This DAX formula checks if the word “iron” is present in the YourTextColumn. If it is, the column ContainsIron gets a value of 1, otherwise 0.
Step 2: Use a Dynamic Filtering Solution
- Create a Parameter Table: Create a table that will house dynamically input text.
- Build a Measure: Use DAX to create a measure that filters based on the input text.
- Create a new table by clicking
Enter Dataand name itParameterTablewith a single column calledSearchText. - Create a new measure in your original table:
FilteredIronItems =
COUNTROWS(Table),
FILTER(
Table,
CONTAINSSTRING(Table[YourTextColumn], SELECTEDVALUE(ParameterTable[SearchText]))
Copy
Code Explainer
Step 3: Use these in your Report
- Create a Slicer for
SearchText: Add a slicer to your report and set it toParameterTable[SearchText]. - Use the FilteredIronItems Measure: Turn your visual to use this measure as a filter, and set the filter condition to
FilteredIronItems > 0.
By using this workaround, when you enter “iron” in the search text slicer, the filtered measure will dynamically show rows containing “iron”, effectively acting like a “select all” for the condition.
DataMentor within the EDNA platform is a great resource to help you with possible solutions to your questions.
I hope this helps.
thanks
Keith
You might also consider creating a classification table that groups similar items (e.g., all items containing “iron”) and linking this table to the dimension table driving your slicer. A slicer based on this new classification enables more efficient filtering based on your current dimension table. You could combine them, with your current dimension nested under the new classification dimension.
Hi @arkiboys ,
You can check EnterpriseDNA Data mentor answer available at:
thank you
