EDNA Forum Good Day
I hope this email finds you all well.
Need a Dynamic Dax Measure that I can put in a slicer that will show the following: for the Water Fall and work with other visuals
MTD
QTD
YTD
TTM
TTM - Tailing 12 Months for example April 2020 - March 2021. Also, when I select a month the Dax measure will recalculate based on the month I select.
Attachment: PBIX
Thank you in advance for your help.
Regards
PBIX_WF.pbix (141.3 KB)
Hi @ambidextrousmentally! We noticed that your inquiry was left unsolved for quite some time now. We strive to answer ALL inquiries in the forum. However, if you are sure that you provided all pertinent context to your concerns and read how to use the forum more effectively and still find your question unanswered, you can check out tutorials to learn this yourself as your membership also comes with relevant resources that may help you with your Power BI education.
