Hi all,
During this whole lock down thing I thought I’d use the spare time to try and learn something new in Power BI. I’ve always wanted to get going with the R and Python visuals and have found a project I’d like to have a go at but need some help replicating. I don’t program in either of those languages but I did have a bit of a bash at doing an R course a little while go so get a little bit of the basics.
I’ve found a little project I’d love to be able to recreate in Power BI if I can and its the visuals within this Epidemic Youttube video. https://youtu.be/gxAaO2rsdIs
If you scroll down to the links underneath you’ll see they use manim an Open Source Python Library so I’m hoping it can be recreated in Power BI. Here are the links to the Github something I’m also new too.
These animations are largely made using manim, a scrappy open-source python library: https://github.com/3b1b/manim
https://github.com/3b1b/manim/blob/shaders/from_3b1b/active/sir.py
Thanks in advance for anyone that can help out.
Cheers
Dave
Hi @DavidNealon, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
When posting a topic with formula make sure that it is correctly formatted to preformated text </>.
Include demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details.
I’ve done this, I can’t provide a PBIX file as I can’t work out how to even get started. I need someone to help me get started with setting up a basic PBIX file with the Github links I’ve provided
Cheers
Dave
Hi @DavidNealon, Due to the length by which this post has been active, we are tagging it as Solved. For further questions related to this post, please make a new thread.
