Showing values only if exists data on the hierarchy
Hi all,
I have a Matrix table with 3 levels of hierarchy.
I want any value to be shown, for example at level 3 if I don’t have any items at that level.
I really appreciate your help.
Regards,
Joao Monteiro
@JoaoMonteiro ,
Based on what you’ve provided, I can only give a pseudocode-ish response, but I think this basic approach should work:
If this doesn’t do the trick, please post a PBIX file and I’d be glad to work through a specific solution with you.
Thanks.
Hi @BrianJ
It works.
Thank you so much.
Regards,
Joao Monteiro
