Showing text and Numeric Values in Matrix
Happy Friday! I am working on a report which shows vacation days for all employees. I have created a matrix visual and would like to have the text ‘HOL’ show up on days that are holidays (i.e. 12/25 and 1/01). We also would need the hours to appear on the days when an employee took leave and have the total hours for the week. Our PBIX contains sensitive employee information so I cannot upload it to the forum.
I have holidays in the dataset, however holiday dates are not assigned to each employee. Those dates are in the DATE DIM table.
Is there a way to write a DAX measure that would have TEXT for Holidays and NUMBERS that SUM for the vacation days? If a DAX measure would not work, maybe a measure to change the background color of the cell would be a better option?
See picture below. Any help would be appreciated.
Hi @kmckee, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hi @kmckee, we noticed that you have not responded to our request above. We are waiting for the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
