Showcase and live demo material
Im having trouble locating the showcase and demo material- where I can download the pbix files?
Rob
Hi Rob,
if you are a member you should be able to access both the data and the courses through the portal. I have included the links below.
Portal- https://portal.enterprisedna.co/
DemoData-http://portal.enterprisedna.co/courses/enrolled/305960
Showcase Data- http://portal.enterprisedna.co/courses/enrolled/305961
If however you mean the free event and live sessions from Sam then they should be available here- https://enterprisedna.co/power-bi-resources
These are normally only available for a specific time period.
Hope this helps.
Regards,
H
Yep as per above everything is located in course modules at the link below
You can also search for anything with the forum here, then go to options
Then select here and type in what you’re looking for
