Hello -
I’d like to have the overall benchmark product side side with the Product per customer. I have attached an example of this. The larger matrix table represents the product mix for each customer. I would like the benmark mix percentages in the next column in this table to match the benchmark percentages in the second smaller matrix table. Currently, the benchmark in larger table is returning the same percentages as the product mix for each customer. Is there a way to remove that customer context and show the benchmark percentage? Thank you in advance.
