When I say “split”, what I mean is that should I create a fact table that has a row for each Primary Care Provider, Billing Provider, and Servicing Provider?
Some records have the same PCP/Billing/Servicing provider.
Hi @kaDargo, did the response provided by Antriksh and Ankit help in solving your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hello @kaDargo , just following up if the response above help you solve your inquiry?
We’ve noticed that no response was received from you on the post above. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @kaDargo, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
