Sharepoint Folder connection taking too long to load
Is it a a problem with the march update or in general that the sharepoint folder connection takes too long to load?
Hi @Anu
Files from SharePoint Folder will generally take more time to load than your Local Folder. There hasn’t been issues due to March version.
Performance will depend on multiple factors like what’s the file size, How is your internet connectivity etc.
Try some tips from below link
Ankit J
Hi @Anu, we’ve noticed that no response has been received from you since the 20th of April. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
