I heard that, Shape map won’t work on power bi service portal due to its still in preview stage. But is their any alternate visual to show insights for US region and that should supports in power bi service portal as well.
Hello @mrommala,
Well shape map is working fine on the Power BI Service. Below is the screenshot provided for the reference of shape map in my PBI Service -
Please try and publish it in your PBI Service.
Thanks and Warm Regards,
Harsh
Hello, @mrommala.
Follow the link that has an explanation of how to implement the shape map visualization in Power BI Desktop.
Best regards
Gifted
@Harsh , @Gifted
Thanks for you quick response!
I don’t see preview option to enable shape visual. looks like due to some security reasons, my companies IT team disabled this preview feature.
Is their any alternate custom visual to achieve it . I tried Choropleth Map visual, but when configure boundary json file for us, I’m getting error on visual saying that “Invalid Json file”.
Hello @mrommala,
You can check out the links provided below. Where there are several other customized maps available. And also providing link of the videos.
Hoping you find this useful and meets your requirements that you’re looking for.
Harsh
https://docs.mapbox.com/help/tutorials/power-bi/
https://www.innovativearchitects.com/KnowledgeCenter/basic-IT-systems/power-bi-custom-maps.aspx
https://appsource.microsoft.com/en-us/product/power-bi-visuals/WA104381472?tab=Overview
Hi @mrommala, did the response provided by the contributors help you solve your query? If not, how far did you get, and what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
