does anyone have experience in extracting data from Service Now to Power BI ?
Hi @mrommala,
Welcome to the forum.
No experience here but if connection is the issue, a quick search revealed these:
I hope this is helpful
Hi @mrommala, we’ve noticed that no response has been received from you since the 19th of March. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
@mrommala you can easily extract data from ServiceNow to Power Bi using this connector which is available on the ServiceNow store
https://youtu.be/qfm7sQ70OEE
