I am currently on a PRO license. I am attempting to automate the sending of PDF paged of PBI reports to different users using Power automate. Some of these users do not have a PBI license and so subscription method is not effective. I have followed along the tutorial below, but my flow is not running successfully:
Hi @musa.fasih, while waiting for others to jump in, have you tried watching the tutorial by @henry.habib on Power Automate to check if this was discussed?
Hi - I have checked it and it is limitation of Power Automate. To Export to PDF, report shall be part of Dedicated workspace. Also, User running the Flow should be part of Dedicated workspace meaning Premium per User license will also not work.
Hi @musa.fasih, did the response provided by @ankit help clarify your concern? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hello @musa.fasih, did the response above help solve your query? It’s been a while since we got a response from you. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @musa.fasih, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
