Hi all,
I have a fairly simple query: I am trying to email different branch managers across the business the table that has details of their jobs as well as the contract value for their job. I know that I can possibly do that by creating filter button for each
Jobs.xlsx (17.2 KB)
of the branch managers and emailing them, but I would like to know if there is a way to directly email all the managers the table with relevant job information using a click of the power automate button. The problem occurs when I edit the Power Automate button, I select the 'Email from PBI data dynamically, and it directs me to the ‘Apply to each section’ so that PBI data is selected in ‘select an output from previous steps’. What this does is that instead of emailing the table containing list of jobs to managers, it instead emails each data item in the table ‘jobs in this case’ to the managers. Is there a way that i can email the entire table to each relevant manager having all the jobs relevant to them listed?
Hi @musa.fasih, I noticed you didn’t provide a PBIX file. Providing one will help users and experts find a solution to your inquiry faster and better.
- A clear explanation of the problem you are experiencing
- A mockup of the results you want to achieve
- Your current work-in-progress PBIX file
- Your underlying data file (to allow us to go into Power Query if necessary to transform your data and/or data model – often DAX questions really end up being data modeling solutions)
My apologies. Here is the Power BI report which includes the Excel file as input.
Power Automate.pbix (26.9 KB)
Hi @musa.fasih, apologies if your post was left unresolved for quite some time now. May I suggest checking the course by @henry.habib on Power Automate. You may check the course here:
Power Automate Masterclass | Enterprise DNA
Hope you will find the solution to this issue. Thanks!
Hi @musa.fasih! We noticed that your inquiry was left unsolved for quite some time now.
