My Send To Back button doesn’t seem to be working. Anyone know why that is? Every time I try to send this Rectangle to the back it doesn’t do it. And this happens on all files so it must be something to do with my Power BI software.
@YusufGillani
You can click on the View tab and then go to Selection. Under Selection you can adjust the Rectangle Button accordingly. Send Back and forward option doesn’t work for me sometimes so I try to move the items in Selection Pane.
In the Selection pane I’ve moved that shape down in the Layer Order
and also enabled Maintain layer order (so it stays in the back, when you click on it in the Service)
