Selective Drill Down
I have a matrix visual with 4 drilldown levels -Master Category, Category_L2, Category_New, Project_New.
However, I don’t want Project_New(4th drill down) to appear under all Category_New values, I just want this 4th drill down level to appear under selected Category_New values say A,B,C
How to do this?
Hi @Anu
Can you please share your pbix file and a screenshot for better explanation.
Ankit
Hi @Anu, we’ve noticed that no response has been received from you since the 17th of February. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
