I am trying to display hide multiple lines in a line chart using a slicer. When the user selects option A they should see one line, if they select A and B they should see to lines
I cannot change the data structure, so potentially a SWITCH function or any other DAX measure would be ideal Sample.xlsx (8.8 KB) sample_bi_line_graph.pbix (44.6 KB)
I have seen a few videos, but am unable to get the DAX to work. Please help, I have attached a sample of pbix and data file for reference
To restrict the values that are shown in a visual, one way is to use an IF statement to check if a particular selection has been made, then return the desired value, otherwise return blank.
Here’s an example:
A Interval % =
IF(
"A" IN
VALUES( SlicerValues[ID] ),
SUM( Sheet1 [A Interval %] ),
BLANK()
It would work easier (and by default, so with no DAX code) if you had a proper data model with fact and dimension tables joined by a one-to-many relationship.
