Having a night of it tonight, i can’t get selectedvalue to work in my following dax calc, i have the budget name column in a slicer and i have selected the correct budget name, I have confirmed this with a seperate card just to make sure but when i try to apply selectedvalue to my Dax it returns blank values, but when i type the value in “FY21Bud” then it works?!?!? I had to remove all the filters as i needed to sum by the parent roll up grouping numbers and not the actual account number so i am tryin to re-apply the filters but for the life of me i can’t get it to work unless i type the value, any ideas?
GL OHead Budget =
VAR COAName = SELECTEDVALUE(COA[Name])
VAR BudName = SELECTEDVALUE(Consol_GLBudget[Budget Name])
Var Calc =
CALCULATE([GL Bud Amount],
FILTER(all(
Consol_GLBudget),
Consol_GLBudget[Acc. Rollup Number] = SELECTEDVALUE(COA[Acc Rollup Number])),
KEEPFILTERS(VALUES(Dates[Month & Year])),
Consol_GLBudget[Budget Name] = BudName) //This does not work if i use selectedvalue but i have checked via a seperate card that the budget selected is the correct one
VAR TblTotal = CALCULATE([GL Bud Amount],
FILTER(all(
Consol_GLBudget),
Consol_GLBudget[GL Number] >= 70000000 && Consol_GLBudget[GL Number] < 78000000),
KEEPFILTERS(Consol_GLBudget[Budget Name] = “FY21Bud”))*-1 //This works if i type the result
Hi @BCS. Please upload your work-in-progress PBIX and a marked-up screenshot of the visual in question showing your desired outcome fro the forum members to review.
Hi @BCS, adding up to what @Greg mentioned above, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster.
Please make sure to:
Hi @BCS, did the response provided by @BrianJ help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
