Segmentation on % for Weekly data
I want to do segmentation of weekly data based on % bin. I have looked at Sam’s video and tried it but not sure how it will work in my situation.
I have this data, I want to group them based on Range/No. Of Weeks and Average cases.
Like here: 20-40% happened 5 times and average cases sold is 3440.
Thanks,
RK
Hi @rit372002,
Fist I marked your Date table as a Date table.
Next there seems to be an issue with your VirtualRangeSelect table. The values do not correspond to the Range Names and the range from 40% ~ 50% is missing…
I lined up the values according to the Range names and created these measures.
No of Weeks =
CALCULATE( DISTINCTCOUNT( 'Calendar'[Week Start Date] ),
    FILTER(
        VALUES( 'Calendar'[Week Start Date] ),
            COUNTROWS(
                FILTER( VirtualRangeSelect,
                    [% Students Virtual Only] >= VirtualRangeSelect[MinValueRange] &&
                    [% Students Virtual Only] < VirtualRangeSelect[MaxValueRange]
            ) > 0
Invoice Case total =
    SUM( OBIQuery[Invoice Cases] ),
    FILTER(
            COUNTROWS(
            ) > 0
with this result (that matches the filtered table next to it)
Here’s your sample file: Community - Modeling v2.pbix (667.0 KB)
I hope this is helpful.
BTW here’s a post by @Greg who gathered more details on this subject you can find that here.
Thanks @Melissa. It fit like a glove. I started with the same path but got jumbled up. Thanks for the wonderful solution.
Thanks,
-RK
