Has anyone worked out how to do segmentation on more than one dimension table?
This is a good example of using one dimension for DAX segmentation:
I am searching for a solution to regroup dimensions based on multiple criteria, across two tables. A
“Sales” example would be displaying Customer Groups (Grouped into global Top, Mid, Low by value), and Products groups (Grouped by global Top, Mid, Low value).
Customers from the Customer table (Customer ID | Customer Name)
Products from the product table (Product ID | Product Name)
Values from the value table (Customer ID | Product ID | Value)
Thanks for posting your question @123kerrod. To receive a resolution in a timely manner please make sure that you provide all the necessary details on this thread.
Hi @123kerrod, we’ve noticed that no response has been received from you since the 22nd of October. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
Hi @123kerrod, due to inactivity, we have tagged this post as SOLVED. If you feel the need to activate the post, we suggest creating a new topic to get a better response from the community. Thanks!
