I´m looking for a script for a calendar table with offset columns.
Some time ago I found one from @Melissa, but now I´m no longer able to find it.
Could you give me the link or Copy/Past the code in here?
Joao Monteiro
Joao Monteiro
Here you go:
P.S. Here’s a link to a helpful Cheat Sheet to accompany the Extended Date Table above:
Hi @JoaoMonteiro, did the response provided by @BrianJ help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
