Schema for Job Search
Hello everyone,
I’m job hunting right now and I’d like to turn this into a data project. Does anyone here have a schema or flat file format that they’ve used to track their job hunt and build reporting off of?
Thank you!
@TuSeproWt,
I don’t have a direct answer to your question, but here’s an indirect way to figure out how to build that schema. Sankey charts are great visuals for representing job-search processes:
Microsoft has a certified Sankey chart custom visual available for free through Appsource. You may want to take a look at how data needs to be structured to populate that visual, and then determine if that structure is sufficient to answer the other questions you want to analyze in your report.
I hope this is helpful.
– Brian
Hi @TuSeproWt, did the response provided by @BrianJ help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @TuSeproWt , we’ve noticed that no response has been received from you since the 5th of May. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @TuSeproWt, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
